2002 Chevy Express Turn Signal Light Problem
Old Nov 16, 2019 | 6:15 PM
Roger1's Avatar
Default 2002 Chevy Express Turn Signal Light Problem
I have a 2002 chevy express. Both front turn signal lights blink when I use either turn signal and the headlights are on. If the headlights are off, then everything works fine.
Any thoughts / suggestions?
Old Nov 18, 2019 | 7:57 AM
wyn_fox's Avatar
Change blinker wiper cruise control arm. You need a z shaped t 20 bit to get it off steering column.
Old Nov 21, 2019 | 6:00 PM
William Kisselstein's Avatar
Sometimes that's a bad ground connection causing feedback.
Old Dec 10, 2019 | 2:09 PM
Ron6519's Avatar
I had the problem and it was the rear wiring harness to the tail lights. Replaced and fixed the issue. Dormann sells this product. Bought it on eBay for under $30.00 for the pair.
Old Dec 11, 2019 | 5:07 AM
I found the rear harness could stand to have the wires soldered to the contacts that actually connect to the bulb, they corrode and the connection gets poor.
Michael Barnes Jr
Aug 18, 2021 12:53 PM
mkmembreno76
Mar 14, 2018 5:28 PM
vw nut
Mar 2, 2010 7:48 PM
checkers355
Feb 2, 2009 10:00 AM
Lobster 207
May 21, 2008 9:10 AM
