2002 Savana Door Panel Conversion
Old Mar 9, 2014 | 11:26 PM
the_engineers's Avatar
Default 2002 Savana Door Panel Conversion
Hi all, noob here.
I have a 2002 GMC Savana from Explorer Conversions. The front door armrests (both sides) have completely bitten the dust. Looks like GM did a poor job engineering this one, as every one that I find in a junk yard has the same problem...the armrests/door handles pull through the screws over the course of time.
It looks like this issue was addressed on the next generation 2003-up. Will the later interior door panels fit my van? Everything I'm reading says they should, but I'd like to know, for certain, before I lay out $300+ for the updated ones.
Thanks!
Old Mar 13, 2014 | 8:22 AM
Would a GM dealership be able to help? Am I stuck trying to buy a panel at a salvage yard and try it on? Most yards won't separate from a good door...
Old Mar 13, 2014 | 9:19 AM
tsbrewers's Avatar
I doubt most dealers will help you out much. The handle on my '06 was also loose, but I fixed it by using some extra washers and glue.
The only other thing I can recommend is to find someone with a newer one to test.
Old Mar 13, 2014 | 6:47 PM
greenfire's Avatar
When my truck was at Maaco for other work I asked them if they could fix that exact problem (on a 99 same deal). They cut a piece of metal to fit inside the opening of the arm rest (where the screws are). Drilled holes to match and put in either bolts or screws. Problem solved.
Artie1
Mar 4, 2025 6:31 PM
Lolzmao
Jul 16, 2012 6:38 PM
corrick
May 18, 2011 9:27 PM
Bob Greene
May 18, 2011 8:56 PM
russellhall63
Feb 13, 2011 1:53 PM
