2005 Express Water Pump
4.8 with 135k. Water pump is weeping and will be replaced this weekend. In addition to the pump, I plan on replacing the thermostat, belts if needed, and flushing the system. I was told to replace the fan clutch as well. Are there any surprises in the r n r that I should know about prior to tearing into this thing, or is it a straight forward operation? Thanks.
The spring is what activates the fan when it gets warm enough.......it does not need servicing......my 2002 has the original clutch and it works fine....
Also when you remove the belt for inspection, turn the idler pulleys to see if the bearings feel okay.....replace them if not.
mtthmpsn
13
June 22nd, 2017 5:48 PM
johowar
May 25th, 2010 10:50 PM
Fightn17
10
April 8th, 2010 12:45 PM
