S-10 & Blazer 1982-2005
water pump
Old Jun 17, 2006 | 10:45 AM
slt's Avatar
slt
Default water pump
99 s10 blazer 4x4 4.3
When replacing water pump. how do you remove the clutch fan? I have removed the belt, pulley bolts, fan bolts, but am unable to slide fan out because of the clutch that looks like it is bolted into the water pump. All of my cars were oldder 80's with regular belts, a fan and a water pump, no clutch. ???? How do you remove that clutch?
Old Sep 17, 2007 | 9:28 PM
sickvortech1's Avatar
Default RE: water pump
hi slt, hope you fixed your problem sence 06. anyhow the fan is bolted to the water pump it has 4
10mm or larger bolts atached to studs coming out of the water pump there a little tricky to get to,use a box end or wrachet wrench to brake them loose. the fan and clutch come off in one piece.
Fightn17
10
Apr 8, 2010 12:45 PM
trevor0520
Dec 20, 2006 5:43 PM
67copo
Dec 11, 2006 2:36 AM
slt
Jun 16, 2006 8:51 PM
