2006 Express reverse/interior lights
Old Feb 20, 2007 | 9:03 PM
grayghostss's Avatar
Default 2006 Express reverse/interior lights
I shorted the wires to my rear dome light while rumagging around in my work van. I cannot find a fuse that corresponds to either the interior lights or the backup lights. Both are non-functional. I've seen this fuse location issue elsewhere but no replies have been posted. Please...help!
Old Feb 21, 2007 | 4:15 PM
golfer's Avatar
Default RE: 2006 Express reverse/interior lights
Did you look in the engine compartment?
Old Feb 21, 2007 | 7:26 PM
The block in the engine compartment doesn't have a fuse designated for this. I checked every fuse that might share the reverse and interior lights-even though the items designated on the fuse schedule worked fine. I will just have to rip out every single fuse and continuity test each one. It's been a little too cold to go through that lately but screw it. I'll post my findings.
Old Aug 24, 2014 | 10:07 AM
namvette68's Avatar
Default 2006 Express back up lights
The fuse is located under the hood. Remove the fuse panel cover on the driver side of the vehicle. Starting from the upper left corner of the mini fuses, to number fuse 18. Pull that fuse, & I think you will find it has blown. Replace the blown fuse and you should be in business.
Old Nov 26, 2016 | 2:53 PM
SimpleTom's Avatar
I had the same problem and checked the fuse #18 under the hood. That was the problem. Thanks namvette68!
Old Dec 11, 2017 | 2:09 PM
mowski9@gmail.com's Avatar
Worked for me too! Thanks! Mine is a 2007 Express 3500
Old Dec 11, 2017 | 3:08 PM
StanVan's Avatar
15 Year Member
The beauty of this style of fuse is that you can test it with a DVM without removing the fuse.
Old Jan 25, 2021 | 11:12 AM
BigJ's Avatar
In my 2005 GMC Savana cutaway it was fuse 11 under the hood.
TB2008
Aug 21, 2019 8:26 PM
Scott Puffenbarger
Dec 12, 2015 8:48 AM
DOUGHBOY123
Nov 15, 2013 3:31 PM
Christopher Krumholt
May 17, 2013 6:10 AM
drakemustaine
Aug 28, 2007 12:32 PM
