Replaced Cats front 02 sensors the injectors were supposedly replaced. I'm having very intermittent misfire almost stalling. If I unhook battery let it sit an hour start back up and idle it's fine for over 30 mins no issues as soon as I start driving over bumps/highway speeds it will start acting up. Not sure if wiring issue? PCM?
I bet there's a separate wiring harness for each bank of injectors and the bank 1 harness is faulty. I don't think they have separate fuses.
Problem doesn't necessarily have to be in the power circuits. It could be the signals going to the injectors too.
First I would just look for the obvious signs: chafed/nicked wires, corrosion in the connectors, and bad ground points.
Yes each bank has seperate fuses. Could be ground/signal doubtful that all 4 on one side having ground issues. Sounds more like voltage drop/short. No the injectors go to PCM no connector for ground and power goes to fuse box.
