2010 Express 2500 Randomly Rough/CEL Flash
Old May 20, 2022 | 7:53 AM
HardlyBoostin's Avatar
Default 2010 Express 2500 Randomly Rough/CEL Flash
​​​​​​Replaced Cats front 02 sensors the injectors were supposedly replaced. I'm having very intermittent misfire almost stalling. If I unhook battery let it sit an hour start back up and idle it's fine for over 30 mins no issues as soon as I start driving over bumps/highway speeds it will start acting up. Not sure if wiring issue? PCM?
Old May 20, 2022 | 3:25 PM
Look at the injector cylinder numbers. Notice anything?
Old May 20, 2022 | 3:42 PM
Yes I checked fuse good. I am assuming it's something with fuse box or power wire going to run new wires to each injector and see if helps.
Old May 20, 2022 | 3:46 PM
I bet there's a separate wiring harness for each bank of injectors and the bank 1 harness is faulty. I don't think they have separate fuses.
Problem doesn't necessarily have to be in the power circuits. It could be the signals going to the injectors too.
First I would just look for the obvious signs: chafed/nicked wires, corrosion in the connectors, and bad ground points.
Old May 20, 2022 | 5:50 PM
Yes each bank has seperate fuses. Could be ground/signal doubtful that all 4 on one side having ground issues. Sounds more like voltage drop/short. No the injectors go to PCM no connector for ground and power goes to fuse box.
Old May 20, 2022 | 7:30 PM
Right you are
Fuses 52, 55
Fuel Injection electrical schematics - Chevy & GMC Vans
MrOldLude
May 2, 2025 10:02 PM
Pierre Daniel
Dec 26, 2019 12:09 PM
Jpdoor
Jul 10, 2018 6:56 PM
Mike Haley 1
Jul 3, 2018 6:33 PM
kalvinklein
Sonic (Aveo)
Jun 23, 2017 10:15 AM
