2011 express no fuel pump
hey guys we got a 2011 express 2500 van that had been acting up and throwing a system lean code so replaced the oxygen sensors, cleared code and went away, drove it 2 more days then cut off. has 0171 permanent code now...fuel pump will not come on, dropped tank and replaced pump and still nothing. new relay and fuse is good, anything else run the pump on these newer vans? thanks!
Check the fuse box under the drivers seat, I've seen a melted fuse box (underside), terminals at the fuel pump fuse, and the wiring harness. The dealer said it burned up the fuse box, and wire harness because we never cleaned the injectors making the fuel pump work harder..... Morons.
The few vans I've seen this on all had 40- 50,000 miles on them 2- 2010s and a 2011.
thanks for the reply! didnt know there was another fuse box under seat only one way down under hood on driver side... yeah this rag box has 51,xxx on it! the terminals on pump looked fine, but who knows...nothing is made good like it used to be.
so all the fuses there and outside are good, fuel pump relay has power but the pump fuse does not. cant even jump it and make it come on...im just about done with it! what a POS.
I dont think I'd own a newer chevy anything with all the problems i see with these rags. we have about 20 of them here and theyre all junk! fuse box looked fine. I dont know what else it could be unless the computer is messed up...
EnyChevyUK
29
July 19th, 2023 7:25 PM
mangomanj
August 17th, 2014 9:51 PM
BRB
December 28th, 2012 8:34 PM
hunter10220
May 18th, 2011 8:37 PM
ross_boss08
August 4th, 2008 2:41 PM
