2011 express no fuel pump
Old Aug 3, 2013 | 5:20 PM
EXPRESS2011's Avatar
Default 2011 express no fuel pump
hey guys we got a 2011 express 2500 van that had been acting up and throwing a system lean code so replaced the oxygen sensors, cleared code and went away, drove it 2 more days then cut off. has 0171 permanent code now...fuel pump will not come on, dropped tank and replaced pump and still nothing. new relay and fuse is good, anything else run the pump on these newer vans? thanks!
Old Aug 3, 2013 | 5:30 PM
200OZ's Avatar
Check the fuse box under the drivers seat, I've seen a melted fuse box (underside), terminals at the fuel pump fuse, and the wiring harness. The dealer said it burned up the fuse box, and wire harness because we never cleaned the injectors making the fuel pump work harder..... Morons.
The few vans I've seen this on all had 40- 50,000 miles on them 2- 2010s and a 2011.
Old Aug 3, 2013 | 5:45 PM
thanks for the reply! didnt know there was another fuse box under seat only one way down under hood on driver side... yeah this rag box has 51,xxx on it! the terminals on pump looked fine, but who knows...nothing is made good like it used to be.
Old Aug 3, 2013 | 7:40 PM
so all the fuses there and outside are good, fuel pump relay has power but the pump fuse does not. cant even jump it and make it come on...im just about done with it! what a POS.
Old Aug 3, 2013 | 8:48 PM
200OZ's Avatar
Did you unbolt the fuse box to get a look at the back side? That is where it seems to manifest first.
Mike
Old Aug 4, 2013 | 12:54 PM
greenfire's Avatar
Rag Box.... lol . Sorry, made me laugh at that one.
Not something I want to read about on newer vans. New owner of a 2013 in about a month.
Old Aug 5, 2013 | 9:30 AM
I dont think I'd own a newer chevy anything with all the problems i see with these rags. we have about 20 of them here and theyre all junk! fuse box looked fine. I dont know what else it could be unless the computer is messed up...
EnyChevyUK
29
Jul 19, 2023 7:25 PM
mangomanj
Aug 17, 2014 9:51 PM
BRB
Dec 28, 2012 8:34 PM
hunter10220
May 18, 2011 8:37 PM
