2011 osrvm
Old March 25th, 2016, 6:27 AM
  #11
jampg's Avatar
Originally Posted by solwav
What about the possibility of the lens snapping in place? Jampg maybe there are no clips.
How about a trip to your local Chevy dealer parts department and inquire about a replacement lens and ask to see the exploded view screen that should show how it is secured.
OK guys, I think I have it figured out. If you rotate the upper mirror all the way up and look into the gap at the bottom you will see two torx screws. Those need to be removed. Then I think the blindspot can be removed. You will then have access to a screw that holds the turn signal lens to the housing. Once the lens screw is removed you will now have access to the bulb.
I will take some photos and come back with better details.
Old March 25th, 2016, 11:30 AM
  #12
canucklehead's Avatar
Originally Posted by canucklehead
Found this on a trailblazer forum.
Pivot the mirror FORWARD to access the secret lens retaining screw on the bottom.
....thats what i said....lol
Old March 27th, 2016, 7:42 PM
  #13
jampg's Avatar
Default 2011 Outside Mirror Turn Signal Bulb
OK guys,
This is what you need to do to replace the turn signal bulb in your outside rear view mirror.
I hope this helps.
Attached Thumbnails 2011 osrvm-20160325_164305_resized.jpg   2011 osrvm-20160325_164523_resized.jpg   2011 osrvm-20160325_194618_resized.jpg   2011 osrvm-20160325_194652_resized.jpg   2011 osrvm-20160327_121351_resized.jpg
2011 osrvm-20160327_121428_resized.jpg   2011 osrvm-20160327_124856_resized.jpg
