2012 express no air conditioning
Old Jul 18, 2024 | 6:45 PM
canadatech's Avatar
Default 2012 express no air conditioning
Hi everyone looking someone that really know these vans
Fixing up this 2012 express for a work truck. My Tacoma is too small.
rats had gotten in to the van a chewed the hvac vacuum tubes. I went to a wrecker and got the hoses.now the setting will move to floor and vents and all but the a/c doesn’t work.
im a air conditioning tech so I put my gauges on the low side and had 15-20psi and put some gas In to get it up to 45. But didn’t want to over charge so now looking for some info.
Old Jul 19, 2024 | 9:23 AM
jfmorris's Avatar
I am not sure you will find specs for charged pressure for high/low side. What you will find are specs for how many ounces of R-134a the system needs - probably in the owners manual, or on a plaque under the hood. The only way to get there is to start with a fully evacuated system, pull a hard vacuum on it, and then charge with that many ounces. When I charge my cars after working on the A/C, I have a small set of scales I use to weigh the last can as I use it up, so that I know when I get to the 34 ounces or whatever I am shooting for, depending on the vehicle. It makes a difference, as you will not cool properly if undercharged (obvious), but also will not cool properly if you over charge the system.
Azmo
Feb 4, 2022 8:26 PM
electrichorseman
10
Oct 12, 2019 4:45 PM
coxpaul
Oct 15, 2015 6:09 AM
PitCrew
Jul 24, 2012 5:22 PM
johnvosh
Cobalt
Jan 1, 2012 3:04 PM
