2012 Express Van- Code P0449
I have 60,000 miles on my 2012 Express Van, 5.3 L, and it just started to show a P0449 code every time I start the truck. I clear it after start up and the "Check Engine Light" stays off until the next start up. I can't seam to find any information of the internet specific to troubleshooting a P0449 code on an Express van. Any input would be appreciated...
I had the same code on my 2007 2500. There was a break in the power wire that powers the EVAP system. As soon as I spliced the break area and plug it into the cannister system I heard the click. Problem solved.
electrichorseman (August 15th, 2020)
I found the break about a foot and half from the switch. I located a diagram of the fuse box thats located in the engine compartment and confirmed that power was going to the switch and from there I just started testing about every 12 inches or so towards the unit and finally found a spot where there was no power and then tested back towards the fuse box and finally closed in on a small spot of discoloration on the wiring. I pinched it and it felt hollow and sure enough the wire was corroded into. So I just peeled off enough insulation to splice it back together, plugged the connector back into the unit and it clicked immediately. Problem solved.
electrichorseman (August 16th, 2020)
Gabe De Simone
February 23rd, 2020 7:13 PM
PitCrew
July 24th, 2012 5:22 PM
gonavi
October 17th, 2010 7:09 PM
