2012 Express Van- Code P0449
Old Aug 12, 2020 | 9:06 PM
electrichorseman's Avatar
Default 2012 Express Van- Code P0449
I have 60,000 miles on my 2012 Express Van, 5.3 L, and it just started to show a P0449 code every time I start the truck. I clear it after start up and the "Check Engine Light" stays off until the next start up. I can't seam to find any information of the internet specific to troubleshooting a P0449 code on an Express van. Any input would be appreciated...
Old Aug 12, 2020 | 9:24 PM
https://www.obd-codes.com/p0449
Old Aug 14, 2020 | 7:03 PM
couchmusician's Avatar
I had the same code on my 2007 2500. There was a break in the power wire that powers the EVAP system. As soon as I spliced the break area and plug it into the cannister system I heard the click. Problem solved.
Old Aug 15, 2020 | 5:05 AM
I read one post on another board that the wiring should be tested. What was the location of the break?
Old Aug 15, 2020 | 6:04 AM
I found the break about a foot and half from the switch. I located a diagram of the fuse box thats located in the engine compartment and confirmed that power was going to the switch and from there I just started testing about every 12 inches or so towards the unit and finally found a spot where there was no power and then tested back towards the fuse box and finally closed in on a small spot of discoloration on the wiring. I pinched it and it felt hollow and sure enough the wire was corroded into. So I just peeled off enough insulation to splice it back together, plugged the connector back into the unit and it clicked immediately. Problem solved.
Gabe De Simone
Feb 23, 2020 7:13 PM
Reflow
Feb 26, 2014 1:11 PM
PitCrew
Jul 24, 2012 5:22 PM
gonavi
Oct 17, 2010 7:09 PM
