2014 Express 1500 Belt Squeal
Hello everyone one. I am the new owner of a used 2014 Chevrolet Express 1500 4.3L V6 van. My issue is a belt squeal on startup. It goes away in about 10 minutes after warmup but is especially worse on wet days or humid mornings. I have about 79k on the odometer and the belt looks to be in good shape. My question is could it be an old belt or is the most likely culprit the tensioner and the belt? Any help would be appreciated. Would like to see if anyone else has had this issue before just throwing money at changing parts.
Thanks in advance!
Thanks in advance!
When you're starting, the belt has to work harder to turn the alternator pulley. If it's shiny and glazed, try roughing it up with a wirebrush or sandpaper. Or if you'd rather use that time to do something else, buy a new one for ten bucks.
https://www.cartechbooks.com/techtips/serpbelt/
Thanks in advance!
Thanks in advance!
So the A/C is not on when I start the engine. I usually leave it off when starting up. It looks like quite the job with all of the stuff in the way to replace it. I've done a few on some toyota's before but it was much more accessible. Has anyone done this on a 2014 or similar van? If so, how difficult was it?
it shouldn't be too difficult. It may be worth it to remove the shroud to get the belt around the fan.
Sorry, never thought you could buy a quality serpentine belt that cheaply.
For a professional mechanic, it is not a difficult job, for a DIY'er you might be asking yourself why you didn't take it to a shop. I have a 2008 1500 with the 4.3, and from what I remember you can't see anything on the front of the engine behind the upper shroud, I think it would have to be removed. Then the long reach to the tensioner to release the belt. And while you're in there I would recommend also replacing the tensioner and idler. You could call a dealer and get a price, and a local reliable shop, to see if it's in your budget.
On my old Astro van (4.3L), which is very similar, it took maybe 10 minutes to remove the belt, and I am not a professional. I used my two foot breaker bar ($12) to release the tensioner.
It wasn't necessary, but removing the shroud involved a handful of screws, accessible from the top.
It looks like it is doable. I have all of the tools. If I am going to replace the tensioner and Idler pulley though it certainly looks easier to remove the upper fan shroud to allow easier access.
