2014 GMC Savana 2500 4.8L - Brake Pull
#11
When the calipers were bleed, there was great flow...so I'm not sure if I'd suspect a kink or blockage in the line...unless you've come across that in life...great flow during bleeding process but kink or blockage in line?
#12
when you bled the calipers, the van was jacked up was it not?
The only other thing I can think of is defective components. It's heat related so maybe a seizing piston or slide pin, poorly made pad linings, warping rotor ...
ekimw2500hd
October 18th, 2023 10:58 AM
Afishinado
July 16th, 2011 7:12 PM
arm425425
February 16th, 2011 10:10 PM
