3500 rear wheel, wheel stud replacment
Old October 17th, 2020, 11:17 PM
  #11
Triaged's Avatar
Originally Posted by tech2
that's news to me. never seen a semi-floating axle in a 3500. it is not designed to handle the weight.
Maybe mine is strange because it is a short wheelbase 3500? It's a 2015 6.0L 12 passenger. I have a 10.5" 14bolt full floater in another truck so I know the difference. Differential catalogs don't list it... like it doesn't exist. It has 14 bolts on the diff cover.
Old October 19th, 2020, 5:21 AM
  #12
what is the cargo rating and gvwr? ... that is what they put in 1500's
Old October 19th, 2020, 10:36 AM
  #13
Triaged's Avatar
GVWR: 9600 lbs. I'm not sure where that puts the cargo rating.
It isn't a 10-bolt. It's a 9.5" 14-bolt semi-floater by what it looks like to me. The springs look setup for the larger axle as the axle tubes neck down before going into the pumpkin.
Old October 19th, 2020, 6:04 PM
  #14
SteveROntario's Avatar
I have a couple videos of the axle found in the 2003/2004/2005 model year 3500s marked as a 70S...mine is also 9600 lbs. You can clearly see it's a full floater when you pull the wheels off. I didn't film much of anything of the internals unfortunately. I always reach in the bottom searching for junk and if it's clean I just put it back together. It must be a tough axle because these vans are workhorses and you don't see many postings about them on the forums.
case310350
Uplander
March 27th, 2020 5:30 PM
Shadetree63
June 22nd, 2015 2:57 PM
Fishinfooleric10@aol.com
September 28th, 2012 12:45 PM
Ronnie-J
September 6th, 2010 11:50 AM
Shaun_95
November 17th, 2009 12:39 PM
Quick Reply: 3500 rear wheel, wheel stud replacment
