92 Chevy Van Fuel Pump Help & Relays Location
I have a 1992 van 5.7 L 3/4 ton and the code reads #54 fuel pump circuit. The pump doesn't hum when I turn the key. I'm just even trying to locate the fuel pump relay. I see a cluster of wires going into what looks like a group of 2 or 4 harnesses? Can't tell cause it has this black foam seal gobbed all over it. It's right above the battery on the firewall. Is one of these the fuel pump relay? I ran a test light and am not getting power back to the pump.
Does anyone have detailed knowledge of the wiring route(s) I should be checking? Any diagrams or drawings/pics? I have the wiring diagram in my Haynes Manual, but it doesn't tell where in the van everything is. Any other tips would greatly help.
If you are not convinced with previous solution then its good to try another one who is expert in car dealership marketing. Great post, got more clarification and new idea on fuel pump.
Keith Moon
November 6th, 2013 10:39 PM
hunter10220
May 18th, 2011 8:37 PM
