92 G20 - Mystery Wire attached to indicator bulb
Old Apr 11, 2021 | 1:13 AM
magconpres's Avatar
Default 92 G20 - Mystery Wire attached to indicator bulb
I pulled my instrument cluster out today to replace some indicator bulbs. These are the PC bulbls that get their electircal connection via direct connection to the circuit board on the back of the palen.
One of the bulbs has a wire attached to it that comes from the harness. It desn't seem to have anythign to do with the dash lighting, but must have some other purpose. That bulb is burned out, but looks like it can be removed from the socket whereas with all the other bulbs, the bulb and socket are part of an assembly and replaced as a unit.
Does anyone know what that wire is for?
I'll try to post a pic tomorrow.
Old Apr 11, 2021 | 5:49 PM
magconpres's Avatar
Here are some pics.
this wire is isolated from the bulb contacts, so it has nothing to do with the dash lghting.
my bese guys is that it own a soon of some sort. Either temp or magnetism.
Old Apr 20, 2021 | 4:08 AM
William Kisselstein's Avatar
Might be to light up the heat/ac head.
Old Apr 23, 2021 | 9:14 AM
dberladyn's Avatar
Fibre Optics.
Old Apr 23, 2021 | 9:53 AM
hanky's Avatar
It does appear to have a fibre optic cable attached. What you could do, see where the other end of the attached cable ends and that should give you some idea of what you possibly not noticed is not indicating an on/off indication. Sometimes it is a small dot that we don't notice is showing the lights are on.
Old Apr 24, 2021 | 5:08 PM
magconpres's Avatar
There's a similar connector on the back of the heater controls, but it is also attached to a bulb. Maybe backup lighting?
I may disconnect it and see what happens.
Old May 28, 2021 | 11:52 AM
circularpastry's Avatar
Originally Posted by dberladyn
Fibre Optics.
Exactly this. I'll try to update w/a pic from my phone but if you have a cigarette lighter there's a fiberoptic light above it.
summershandy
Feb 19, 2016 4:46 PM
stimutaxed
Feb 27, 2011 9:13 PM
mikew2069
Oct 22, 2009 1:22 PM
shnormo
Feb 12, 2007 12:54 AM
