94 G-20 fuel tank size
Old Oct 16, 2019 | 11:26 AM
jimmydriver's Avatar
Default 94 G-20 fuel tank size
I need to replace my sending unit because it stops reading at about 3/8 of a tank. I was going to order new tank straps to make the job easier but I don't know which size tank I have. Is there a digit in the vin that would say? There's no sticker under the hood or in the door opening giving the factory equipment specs.
Old Oct 22, 2019 | 5:58 PM
joelsplace's Avatar
I know on my C30 you can tell the difference by the way the lines come out the top of the sender. Rockauto has good pictures and there should be a tag on the wiring on the sender with a code that helps also.
Old Oct 23, 2019 | 1:18 AM
oilcanhenry's Avatar
Its been discontinued by GM but its 33 gallons according to GM itself. The link for proof is located here:
http://ttps://www.gmcertifiedparts.c...QtM2wtdjYtZ2Fz
wolfedc33
Mar 30, 2017 1:56 AM
mudcat5
Mar 28, 2014 11:37 AM
tamula
Mar 20, 2014 9:42 PM
bwexler
Jul 31, 2013 10:13 PM
lowred1
Jan 9, 2012 7:17 PM
