98 express brake light problem!
Old Dec 7, 2010 | 10:08 PM
jgourley5315's Avatar
Exclamation 98 express brake light problem!
I need a wiring diagram for the tail lights on a 98 chevy 2500 van. I have checked the fuses, replaced the brake light switch (on the pedal), replaced the left side pigtail. The connector for the brake light switch had some corrosion on it so I took it apart and cleaned it up and realized that the light green wire is hot and when I touch the White wire to the light green one the brake lights come on. Any help would be great, Thank you!!
Old Jan 1, 2011 | 9:19 PM
Athanatos's Avatar
hope this can help
Old Jun 9, 2012 | 1:54 PM
jvwells's Avatar
Does the power go from the battery to the fuse then to the brake light switch at the brake pedal then to the brake lights?
Old Jun 9, 2012 | 2:04 PM
kevinkpk's Avatar
Yes thats is correct.
Old Jun 10, 2012 | 1:56 PM
Got Options?'s Avatar
Default brake light problem
Not sure if this problem is related but I had problems with my express cargo van brake lights and the only fix was to replace the sockets and harnesses on both sides and replace ALL the bulbs.. Water rusted a bulb or two and the sockets wear out easily.
I had all kinds of strange things happen before I did this, Some lights went dim some went too bright, sometimes they responded sometimes not.
paulg_ca
Oct 24, 2014 5:42 PM
jimmys57chevy
Aug 22, 2012 8:45 PM
ericmckinney
Uplander
Oct 14, 2011 10:35 PM
beckya99
Jul 12, 2011 12:29 PM
ShawnInDallas
Feb 27, 2010 8:18 AM
