ABS Activates at Brake Application 2003 3500 Exp
Old June 20th, 2021, 9:20 PM
  #11
pull the abs fuse. this will stop the abs problem untill its fixed. You will still have regular service brakes but no abs interaction.
Uptownsport (June 20th, 2021)
Old June 21st, 2021, 5:01 PM
  #12
Uptownsport's Avatar
WILCO.
Dunno much of anything, but I'm guessing theres supposed to be a cover over those windings and the cover's still in the bore.
Old June 21st, 2021, 8:21 PM
  #13
yep its f'ed
a spiral shaped wine cork remover is what i use to pull the cap out. some folks drill but be careful to not hit the reluctor
Uptownsport (June 21st, 2021)
Old June 22nd, 2021, 9:39 PM
  #14
yep its f'ed
Thanks!
HOW do you get the hub nut off the rear?
There's spot for six spanner notches, and some type of tab.
Old July 8th, 2021, 11:42 PM
  #15
Thanks- I got catastrophic level brake failure, rust hole.
I had to put a union in the line in a parking lot in the middle of nowhere.
I did install the new sensor and, best I can tell w 5% pedal it works.
Old July 13th, 2021, 9:57 PM
  #16
Yep. Best I've ever seen it.
tech2 (July 13th, 2021)
dowdytf
December 30th, 2018 5:46 PM
quasipredator
1988 - 1998 (GMT400)
February 12th, 2018 5:20 PM
Just1creation
November 22nd, 2014 11:39 AM
pcesso
Avalanche
July 6th, 2011 12:57 PM
ShawnInDallas
February 27th, 2010 8:18 AM
Quick Reply: ABS Activates at Brake Application 2003 3500 Exp
