ABS anti lock brake issue
Old Oct 13, 2011 | 4:27 PM
primesuspect's Avatar
Default ABS anti lock brake issue
My 95 G30 van started pulling to the right recently.
I checked out the left side front by bleeding it and I get only residual fluid from the caliper.
I followed the brake hose to the brake lines all the way to the ABS and tried bleeding each disconnect. No fluid in the line.
The front right has fluid which is pumped when the pedal is depressed. Also the lines into the ABS from the master cylinder are pumping fluid when bled.
I assume the ABS is blocked or it is not pumping.
I am not sure how to determine that the problem is in the ABS pump Or ABS computer. I have no ABS light on.
Any recommendations about buying and installing a used ABS pump or computer or repairing an ABS would be greatly appreciated.
Old Oct 13, 2011 | 9:53 PM
RacerX's Avatar
or maybe it is just an underinflated tire?
cmh63025
Jul 17, 2013 1:52 PM
Newto4x4
May 9, 2013 1:34 PM
angelbaby21
Nov 14, 2012 9:52 PM
Michael Clogher
Jan 18, 2010 1:12 PM
Notpil22
Jun 19, 2006 11:01 PM
