AWD front hub and axel torque specs
2004 1500 AWD express. need info on front hub replacement torque specs: axel nut , hub bolts , brake mount bracket . also when I tried to tighten the hub axel nut down to 75 lbs with air tool , i went a little over the 150lbs. I lossened the axel nut and retorqued to 150 lbs. did I hurt any thing?
I called a tech line 8667702771 he said the axel nut is 155 lbs , the three hub bolts were 96 FT Lbs, the caliper braket is 129ft lbs, he said if I over tightened the axel nut it would make a whirring sound, if the bearings had indented into the races. tested that out today , no noises
mcphck
August 21st, 2012 5:37 PM
1988scotdale
October 5th, 2010 1:45 AM
