Battery charging system battery light on
Old February 10th, 2024, 3:07 PM
  #11
So again, you need to go get your alternator tested. It's free!
Was that photo taken with the van running? The voltage is too low. Your alternator is probably fried.
Rednucleus (February 10th, 2024)
Old February 10th, 2024, 3:08 PM
  #12
Idkchevy1234's Avatar
Yes sir it was on yea I'm thinking my altenator is going out how many days can I drive my van like this
Old February 10th, 2024, 3:44 PM
  #13
maybe about half an hour if you full charge the battery before you leave. No promises.
Old February 10th, 2024, 3:48 PM
  #14
yea I'm just going to replace it hopefully that's what it is I just replace it 2 years ago
Old February 10th, 2024, 3:54 PM
  #15
Alternators should definitely last more than two years (unless you have other issues going on)
Maybe the alternator isn't bad , and you just have some crusty wiring, in which case buying a new one won't do anything.
Always test + diagnose before throwing your wallet at problems.
Old February 10th, 2024, 4:40 PM
  #16
tested my altenator wit my multimeter getting 12.1 v
Old February 10th, 2024, 4:48 PM
  #17
Rednucleus's Avatar
So it's not working - where did you put the test leads?
Old February 10th, 2024, 4:54 PM
  #18
wit vanwith 12.5 when turn on 12.1 so yea it's messing up positive behind the screw and negative on base of alternator
Old February 10th, 2024, 5:42 PM
  #19
so I have a different question behind the serpentine belt there's another smaller belt how do I replace that belt
Old February 10th, 2024, 8:46 PM
  #20
From below, looks like. If there's no tensioner, then it's a pre-tensioned belt and you need a prybar or something to get it off. Is it slipping?
Service manuals are on charm.li
Quick Reply: Battery charging system battery light on
