Best up grades done
#385
I did it step by step like you posted in #357 & #358, maybe StanVan can try it on his?
#387
ARTIE1
Posted By: Teammuir1
7. Select "Transmission Fluid Temp (GM Method 2)"
Yes Teammuir2, you figured out the transmission temp right. Also thanks for posting on the oil pressure PID, I am going to add it to mine. Although the cluster gauge is quite accurate too but would be neat to know actual numbers!
Posted By: Twscarp
Hi, is the outside temp, in your available green list? It is on my 08 and seems to work. Think Artie1 said the computer has to have a sensor to be picked up by Torque, which I thought was the green list. Can you add items like the trans temp, if they are not on the green list?
Can confirm, the 2008+ vans do indeed show the outside temp, but they don't show transmission temp, current gear, and torque converter slippage. The pre-2007 show the opposite. The closest I got for the outside temp was the air intake temp, which only approaches real outside temperature during long highway runs. City driving, it shows a lot higher.
I am even more confused... Were did you read that I am ( Teammuir2 )
LOL.... I caught it when I read the post back a while ago.... but since forgot about it ... lol.... but its TEAMMUIR1....
And your Welcome I will post every one I find for you guys.... if it helps someone else out... thats what the forum is all about.
helping and sharing with one another...
Posted By: Twscarp
#390
STAN.. my Son says its ELMO' VAN....
so I thought about getting a toy elmo...
my wife on the other hand didnt think that was a good idea....
( reason ) someone might get the thought of a pedifile driven the van.....
LMAO.. thas just not right..
