Best up grades done
Old November 24th, 2017, 9:07 AM
  #411
Teammuir1's Avatar
I am using METHOD 1
PID 221940 all the same values but I changed edited the C to F
Old November 24th, 2017, 9:22 AM
  #412
Teammuir1's Avatar
ARTIE1
you mentioned for me to change decimal on my gauges... I like that idea... but your instructions are very vague
as you said to hold long on the gauge and go to settings..
here is a pic of what I get when I hold long on the gauge....
there is NO settings menu maybe you left a step out ?
I dont know... I am using Torque Pro
Attached Thumbnails Best up grades done-looking-change-decimal-bar-graph.jpg
Old November 24th, 2017, 9:25 AM
  #413
Teammuir1's Avatar
OK CRAP..
I went back and re read.. I gave you Trans temp PID...
I will work on the Oil pressure next..
Old November 24th, 2017, 9:38 AM
  #414
Teammuir1's Avatar
Oil pressure pid
pid # Long Name Short Name Min Value Max Value Scale Factor Unit Type Equation OBD Header
22115c Oil Pressure Oil Prss 0 200 x1 PSI (A*0.65)-17.5 AUTO
Old November 24th, 2017, 9:39 AM
  #415
Teammuir1's Avatar
OK thats some crap once again
I previewed my post and it looked just how I wanted it too I posted and it came up just like this garbled crap
WTH.. it wont stay the way I wrote it..
Old November 24th, 2017, 9:45 AM
  #416
Teammuir1's Avatar
Try this again.....
PID # ........LONG NAME......SHORT NAME .....MIN VALUE....MAX VALUE.....SCALE FACTOR.....UNIT TYPE.....EQUATION.....OBD HEADER
22115c}}}}}}}}}}}}}}}}}}}}oil pressure}}}}}}}}}}}}}}oil prss}}}}}}}}}}}}}}}}}}}}}}}}}}0{{{{{{{{{{{{{{{{{{{ {{{200}}}}}}}}}}}}}}}}}}}}}}}}}x1{{{{{{{{{{{{{{{{{ {{{{{{PSI}}}}}}}}}}}}}}}}}}}}} (A*0.65)-17.5 }}}}}}}}}}}} auto
MAIN thing about the pid number.. DONT FORGET to put the c in there.. I did and it didnt work.. 22115c
Old November 24th, 2017, 9:47 AM
  #417
Teammuir1's Avatar
STAN let me know if that works for you since I know your vehicle is a newer one... will be interesting to know.....
I am wanting outside temp...
Engine Oil Temp
I am researching ( looking on the net )
Old November 24th, 2017, 10:35 AM
  #418
Twscarp's Avatar
Originally Posted by Teammuir1
ARTIE1
Long touch, Display configuration..., then Number of decimal places, enter 0, uncheck Use display default, touch OK.
Old November 24th, 2017, 10:54 AM
  #419
Teammuir1's Avatar
ARTIE 1
That worked perfectly.... Thanks.....
I found and installed
Fuel % used. which tells how much Fuel is left in the tank... Kinda neat ....
Old November 24th, 2017, 11:00 AM
  #420
Twscarp's Avatar
ARTIE 1
You mean thanks, Twscarp? Or did you figure it out without my explanation?
Quick Reply: Best up grades done
