Blower not blowing
I have a 2016 Chevy Express 3500 6.6L Diesel. My van's blower does not turn on with the ***** in any position ... with the one exception that once-in-a-random-while it will turn on weakly with the **** in position 3.
Here is what I have tested so far:
Thanks for any help or suggestions.
- I started at the blower motor, and applied 12v from the battery. The blower turned on.
- I replaced the resistor module, no change, so I returned that.
- With multimeter, I checked for power from the pigtail that attaches to the blower motor. No power with the **** turned to any position.
- I checked for power at the harness that plugs into the resistor. Only power if I test against the fat red & black wires. No power from the tan, blue, orange, or yellow with the **** set to any position.
- I checked the fuses visually and with a test light - they seem good.
my blower absolutely quit working in my 07 3500 express. on disassembly, we found some mouse had gotten in and built a nest of junk. and eaten some tasty wires too. replacing the blower was the fix. the wires were a mess --I guess they taste good to mice.
no. see Chilton ch 3.10 for procedures in checking wiring in heater/air conditioner control assembly ( the 3 rotary switches on p side dashboard. ) it was easier for me us to start under the hood by examining the blower motor itself. ) complete replacement of the blower motor was cheaper and less work.
