Blower not blowing
Old Apr 8, 2025 | 7:14 PM
Marshmallow3500's Avatar
Default Blower not blowing
I have a 2016 Chevy Express 3500 6.6L Diesel. My van's blower does not turn on with the ***** in any position ... with the one exception that once-in-a-random-while it will turn on weakly with the **** in position 3.
Here is what I have tested so far:
  • I started at the blower motor, and applied 12v from the battery. The blower turned on.
  • I replaced the resistor module, no change, so I returned that.
  • With multimeter, I checked for power from the pigtail that attaches to the blower motor. No power with the **** turned to any position.
  • I checked for power at the harness that plugs into the resistor. Only power if I test against the fat red & black wires. No power from the tan, blue, orange, or yellow with the **** set to any position.
  • I checked the fuses visually and with a test light - they seem good.
I now have the control module pulled out of the dash and it is sitting on the desk in front of me. I feel like there is more I should be able to test before I just buy a control module to see if that fixes it. But, I am not sure what to test next.
Thanks for any help or suggestions.
Old Apr 9, 2025 | 10:07 AM
MitchM's Avatar
15 Year Member
my blower absolutely quit working in my 07 3500 express. on disassembly, we found some mouse had gotten in and built a nest of junk. and eaten some tasty wires too. replacing the blower was the fix. the wires were a mess --I guess they taste good to mice.
Old Apr 9, 2025 | 10:36 AM
Did you test the blower motor relay?
Old Apr 10, 2025 | 5:29 AM
MitchM's Avatar
15 Year Member
no. see Chilton ch 3.10 for procedures in checking wiring in heater/air conditioner control assembly ( the 3 rotary switches on p side dashboard. ) it was easier for me us to start under the hood by examining the blower motor itself. ) complete replacement of the blower motor was cheaper and less work.
mikey379
Jun 28, 2025 11:15 AM
trbsami
13
Dec 3, 2023 6:50 AM
rodp14
Apr 17, 2023 6:53 PM
AngryDad
Mar 29, 2014 3:41 PM
Srock67
Jan 1, 2014 12:19 PM
