Blowing spark control modules
Old Jul 31, 2023 | 11:47 AM
  #11
Triaged's Avatar
The part should come with some but you never know. Should also come with directions but who reads that stuff? You could order some thermal compound from
Amazon Amazon
(or wherever) for less than $10. Hardest part should be taking the engine cover off. Buy a new ground strap while you are at it. Heat transfer is best between flat smooth surfaces. You might need to sand both surfaces flat and smooth stepping up on grit. Quick search found this for diagnosis: https://easyautodiagnostics.com/gm/4.3L-5.0L-5.7L/distributor-mounted-icm-tests-1
Old Jul 31, 2023 | 5:25 PM
  #12
Welcome to the forum.
Old Aug 13, 2023 | 8:37 PM
  #13
wzard1's Avatar
Okay guys. So I bought the heat paste from Amazon and applied it to the ICM. I also changed the cap and rotor while I was there. Used an Accel unit this time.
Cleaned up all grounds and replaced the main, (motor to frame one). So took it on a few short trips around town. Made sure I was at operating temp and all was good so far.
This is my travel van. I am not sure about taking it on a journey just yet. Thanks for all the help you guys and I will let you know how it goes in the future.
Old Aug 13, 2023 | 10:33 PM
  #14
Triaged's Avatar
Was there paste under the ICM when you took the old one out?
Old Aug 14, 2023 | 2:57 AM
  #15
wzard1's Avatar
Yes, just a smidgen. Nothing like the full on slathering I did when put it on.
Old Jun 4, 2024 | 6:08 AM
  #16
wzard1's Avatar
Ya, believe it or not , just pulled the van out of storage. Drove down the block the van died waited 5 minutes started it up and drove home. I' F****d!
Noir Taylor
Feb 27, 2017 9:26 PM
Cajunbeano04
Site Feedback
Oct 26, 2016 11:55 AM
Express
Oct 30, 2012 10:44 AM
