Both tail lights dead , worked 2 weeks ago
2005 standard panel van ,
Both tail lights are dead , no power to the plug using a test light ,
I checked the fuses under the seat and they are OK
I checked the fuses under the hood and they are OK ,
Is there another fuse to check that is not marked as a light on the chart ? or a wire to wiggle
Could it be the dash switch ? and how would I check that switch.?
any ideas ? What to check ? How to "hot wire" it from the fuse box if I have to....
Thanks for your ideas
on my 07 express 3500 I had series of problems w the the driver side tail light not lighting, but the passenger side was lighting fine. the fuses were good. I found using chitons wiring diagrams that there must be a pinched or corroded hot wire connection coming into to the driverside rear taillike assembly. that wire was supplying amps to the L driver side taillight bulb. using a clamp on dc ammeter (fluke 320) I meaured amps in the hot wire to the taillight bulb assembly driver side with the amp flow into passenger side tail light . driver side was getting a lot less amps than passenger side lamp . then for curiosity I measured amps into the other lights like reverse, etc. for both sides. There was deteriorated wiring coming into the driver side rear lamp assembly. I bought a whole new driver side rear lamp assembly off the internet for about $90 which fixed the problem. (note that all my fuses were good. )
chevy2010
Apr 19, 2010 5:44 PM
