Bought a beautiful Express conversion van, but realized it has some rust underneath
Sean Rothar (February 25th, 2021)
#32
I would avoid ziebart like the plague. I agree with Eric O. on the South Main Auto channel on youtube, have a company spray the undercarriage with fluid film or krown or a similar undercoating yearly.
#33
#34
https://youtube.com/watch?v=wSg0yvwcbXA
Watching the installation now - Eric is great
Thank you
#35
Oh yes, in Boston, coat the hell out of it, remove the plastic plugs under the body lip and clean out inside and have coated in there too. Take the door panels off the rear and side doors and have the bottom 12" of the inside of those coated. IIRC MA fails your inspection for rust holes in the body.
I have to say the 03-up seem to have better factory rustproofing than the older ones do. But the frame itself can rot in them. That rear spring perch I have seen with holes in them, too.
Sean Rothar (February 26th, 2021)
#36
What's up you all, I Thought I'd check into this forum and give you an update on my van.
The van looks the same as the picture. I haven't driven it all that much since I bought it 3.5 years ago. I've put about 5 thousand miles on it. I've had no issues at all. It did shift a little hard from first to 2nd gear. It could be a solenoid in the transmission I've read. My mechanic did a tranny fluid/filter change. He also added Lucas treatment to it. It seems to have smoothed out a bit.
I sure wish I could put a lift kit on this van and some bigger tires, but then it wouldn't fit in the garage. I'd have to park it in the driveway which my mom isn't crazy about. Anyway the van stays nicer and is certainly safer in the garage.
RoadTrip (September 26th, 2023)
Orbit World Fitness
September 13th, 2011 2:01 PM
