Brake light output power
Old Sep 30, 2020 | 8:44 PM
GeneveConversionVan's Avatar
Default Brake light output power
Forum,
Is there a way to improve "intensity" of brake lights? I have tried with a number of different led bulbs, but neither of them make a lot of difference between "Low" beam and high beam. I was wondering if it has anything to do with something else than the bulb itself (maybe the fuse). The third light works great and with all lights off, the brake light turns on right on, the problem is when lights are on and I hit the brakes, almost no noticeable difference.
Old Sep 30, 2020 | 9:07 PM
SteveROntario's Avatar
The brake lights should be brighter than the tail lights. Do you have the bulbs in backwards?
Old Sep 30, 2020 | 9:27 PM
For a moment I thought it could be the case, but then I reaized that there is only one way to plug the bulb, isnt it? is BAY15D.
Old Oct 1, 2020 | 10:27 PM
You can look at the filaments with both the park & brake light on to determine if you have it correct. LED doesn't really work in this application.
Old Oct 2, 2020 | 9:27 AM
Is what I think its the issue, LED. Too bad as Im going to miss the "immediate" turn on and superb brightness.
rossington2
Oct 25, 2018 2:36 PM
calemleyjr
Uplander
Feb 16, 2018 7:37 PM
jake63
Jan 7, 2016 12:11 AM
kingpinofdisks
Colorado
Jul 10, 2012 11:41 AM
rigginfit
Aug 22, 2009 10:53 AM
