Brake Rotor Question
Old Apr 1, 2014 | 3:16 PM
93ChevyVan's Avatar
Default Brake Rotor Question
So I had the rotors and pads replaced on my 1993 G20. Not a cheap repair as the rotors cost more due to the built in wheel hub. Anyway, that was last year and 20,000 miles ago. Now the rotors feel like they are warped. They are NAPA brand and went out of warranty 6 weeks ago. A mechanic told me that an error was made in the installation last year. The rear brakes were not adjusted at the time the fronts were done causing all the braking to come from the front rotors, hence, warping them prematurely.
Does this make sense? I've never heard this reasoning with a brake job, but I do have severe wobble in the wheel when I apply the brakes.
Old Apr 1, 2014 | 11:56 PM
tsbrewers's Avatar
the fronts do the majority of the braking in general, but that being said, it does make sense if the backs weren't working at all, that the front ones warped.
I would go talk to napa and see what they say. 6 weeks might be close enough for them.
Old Apr 2, 2014 | 12:10 AM
canucklehead's Avatar
No. Makes no sense. It would be pretty hard to warp those rotors. Are you sure that they are? If the caliper slide pins get rusty at the ends then the caliper won't float properly and you get uneven pad wear and so on.
What is the rest of the front brakes like?
Rear brakes self adjust, so your mechanics comment sounds like bs to me.
Are the rotors beyond turning?
Need more info.
Old Apr 2, 2014 | 5:53 PM
greenfire's Avatar
I'm not so sure you have warped rotors. You say a wobble in the steering wheel. You should feel a pulsating in the brake pedal. The harder your brake the worse the pulsating.
Old Apr 3, 2014 | 3:52 AM
SnlpeR's Avatar
I had warped rotors
Once the brakes were heated up, the steering wheel and/or brake pedal would pulsate
I figured it would be pointless to have my rotors turned because it only shook when the brakes were hot
i replaced the rotors and pads on the front and everything is good
scorpion48
Jul 5, 2012 6:28 PM
rich_ncal
Jul 2, 2008 3:04 PM
Idiot
Jun 11, 2008 9:31 PM
joescat
Apr 26, 2006 12:39 PM
