A/C blows hot when idling
Old June 28th, 2022, 10:36 AM
  #11
RobbyMartin's Avatar
Originally Posted by pomerlo
When the magnetic clutch refuse to engage what is the engine temperature gauge read ?
Even if the radiator fans kicks in... it could be a defective coolant thermostat or a defective water pump.
You must be shure the engine is not overheating.
There is a possibility that the PCM cancel your A/C if it reads correctly or incorrectly a high engine temp.
Here
I'm not sure what the temp is while idling but on the freeway it's about 210.
Old June 29th, 2022, 1:17 AM
  #12
oilcanhenry's Avatar
190 to 210 F is normal range.I'd put a thermometer on it at when idling, however.
Did the tech ever tell you what the pressures were?
Old June 29th, 2022, 7:08 AM
  #13
Unfortunately, no. He was a mobile mechanic with little AC experience but he had guages and apparently knew enough to say that they were reading right. Maybe he was BS'ing me because he didn't want to screw with it.
Old June 30th, 2022, 4:31 AM
  #14
That's unfortunate. Makes diagnosing your issue harder. I wonder if a parts store could check the pressures? They sell cheap A/C gauges at places like Harbor Freight, for about $30 bucks,They might be close enough to work, but no professional would buy one. I suspect your pressures are OK if your A/C does get very cold, when it works.
Johnny Mayday
November 1st, 2018 7:09 PM
kscott1994
May 18th, 2015 4:40 PM
Manny559
July 7th, 2014 12:40 AM
slapmonkey
August 5th, 2009 9:44 PM
dozuki
March 10th, 2009 6:34 PM
Quick Reply: A/C blows hot when idling
