Can someone help me out with some torque specs?
Old Dec 2, 2011 | 9:01 AM
mharrelson's Avatar
Default Can someone help me out with some torque specs?
Hello,
I get my front differential back from the machine shop today and am planning on rebuilding and installing tomorrow. My GM manual won't load and I have not had any luck finding torque specifications online. I'm looking for the specs for:
the diff. case bolts
bolts that hold the axle to the case
bolts that hold the axle to the cv joint
differential mounting bolts
If anyone has this information I'd really appreciate it, or if you can point me in the right direction.
The vehicle is a 2005 express AWD 5.3l.
Thanks!
Mark
Old Dec 2, 2011 | 6:41 PM
mharrelson's Avatar
I finally got my GM manual working on the computer and found what I needed. Here it is in case anyone else needs it. I got all new bushings (4) and (2) bearings pressed from the machine shop for $110, parts were $135 total. Installing it tomorrow.
the diff. case bolts - 35lbs
bolts that hold the axle to the case-short side 13lbs, long side 35lbs
bolts that hold the axle to the cv joint- *use threadlock-58lbs
differential mounting bolts-*use threadlock - 63lbs
Drain and Fill - 24lbs
Mille Racer 69
12
Aug 5, 2011 11:37 PM
MZHUSTLER2265
Jul 31, 2009 10:33 AM
Mud_Truckin
Jun 4, 2009 1:53 PM
karmazero
Oct 18, 2008 10:34 AM
DonaldB
Sep 29, 2007 2:53 PM
