Center Console removal ????
I have a 2002 Express Conversion (Explorer) and I want to remove the engine cover to replace plus and wires. I have removed every nut & screw I could find, and still canot get the trim off. When I pull the bottom it appears the be connected to the underside of the dash ( I removed the 2 screws on each side) but I cannot find by what. I know the straps must be disconeceted to remove the housing.
Any input would be appreciated.
Thank you,
bluegold
I found the two bolts holding the unit.
Thank you,
bluegold
Last edited by bluegold; May 9th, 2012 at 4:08 PM. Reason: Found the bolts holding the top of the unit.
AnnaRiling
October 3rd, 2023 12:24 PM
ChevyTruck55
July 3rd, 2015 11:16 AM
Danistheman1234
May 18th, 2011 10:49 PM
Danistheman1234
May 14th, 2011 8:55 PM
