Center Console removal ????
Old May 9, 2012 | 3:16 PM
bluegold's Avatar
Default Center Console removal ????
I have a 2002 Express Conversion (Explorer) and I want to remove the engine cover to replace plus and wires. I have removed every nut & screw I could find, and still canot get the trim off. When I pull the bottom it appears the be connected to the underside of the dash ( I removed the 2 screws on each side) but I cannot find by what. I know the straps must be disconeceted to remove the housing.
Any input would be appreciated.
Thank you,
bluegold
I found the two bolts holding the unit.
Last edited by bluegold; May 9, 2012 at 4:08 PM. Reason: Found the bolts holding the top of the unit.
AnnaRiling
Oct 3, 2023 12:24 PM
ChevyTruck55
Jul 3, 2015 11:16 AM
Danistheman1234
May 18, 2011 10:49 PM
Danistheman1234
May 14, 2011 8:55 PM
c.holway
Jul 17, 2006 5:36 PM
