Hello everybody...
my oil pressure is constant at 100%, I suspect that the oil pressure sensor is defective and will replace it.
My question: where do I have to solve something to remove the doghouse? Are there any screws that need to be loosened somewhere?
And can the console with fridge and DVD player stay in or does it have to be removed before, so I can push the doghouse back enough?
My VAN is a 2006 GMC Savana Explorer Limited SE with 5.3
Hello everybody...
Greets from Germany
René
Hi, not sure where your fridge and DVD player is, I couldn't see them in the picture. I always remove the cubby, will give you more room, 4 10mm bolts holding the cubby. Also to get the doghouse completely out of the way, you can remove the 4 18mm nuts holding the passenger seat, disconnect a couple electric plugs, and put the seat in the back of the van.
