Changing out the Antenna
Old Jun 27, 2020 | 8:56 PM
Claudia J Morgan-Andrade's Avatar
Default Changing out the Antenna
Hello, my 2006 3500 Express Van lost its antenna at the car wash...2 questions: #1 How difficult is it to replace and #2 is there a shorter type antenna less prone to snapping off that can be used instead. Thanks.
Old Jun 27, 2020 | 11:02 PM
should just unscrew from the mast. there are shorter antenna but they may not work as well. the antenna length correlates to the wavelength of the radio signal so if you like fm...bigger is better.
Old Jun 28, 2020 | 12:15 AM
It is snapped at the base...I think I need to go in and remove it from the mount. I have not even looked under hood yet, was googling, and have seen some posts indicating I might have to go through the wheel well...Just trying to determine if I can do this or do I need to take into my mechanic. Thank you for your prompt response.
Old Jun 28, 2020 | 3:08 AM
Vans4Life's Avatar
Default All I could find on Alldata was to change Antenna wire replacement, this should hel
[QU
OTE=Claudia J Morgan-Andrade;449826]Hello, my 2006 3500 Express Van lost its antenna at the car wash...2 questions: #1 How difficult is it to replace and #2 is there a shorter type antenna less prone to snapping off that can be used instead. Thanks.[/QUOTE]
Old Jun 28, 2020 | 4:48 PM
Thank you so very much!!!!
Old Jun 28, 2020 | 8:55 PM
Vans4Life's Avatar
Hope that helps you or gives you an idea of how it's set up
That was for a 2005 Chevrolet Express 1500 Conversion van
mvanslee
Sonic (Aveo)
Feb 4, 2019 7:11 PM
banner1124
Oct 26, 2015 6:33 PM
forced1nyc
Dec 22, 2008 7:18 PM
kklaus
Sep 4, 2006 12:14 AM
randomizer
Sonic (Aveo)
Jun 3, 2006 9:46 AM
