Chevy express 3500 won't power fuel pump
Old May 1, 2012 | 1:53 PM
chris 419's Avatar
Default Chevy express 3500 won't power fuel pump
First time as a poster. I have a 99 3500 chevy express. It died and the fuel pump doesn't make any noise when I key it on. The fuel gauge is tapped to full. I fed power to the pump and pump works. I hooked up an obd 2 and it won't make a connection. changed out fuel relay. Only getting .2 volt to pump when keyed on. Can anyone help or at least give me a direction to go in?
Old May 13, 2012 | 10:29 AM
chris 419's Avatar
Changed out the computer in my van That didn't fix the problem. Apparently I've been chasing ghosts because I don't have spark either.
Old Apr 30, 2013 | 2:00 PM
jhuston936's Avatar
Default G3500 Fuel Pump Issue
Did you get a solution to your fuel pump issue? I have the exact same problem.
Old Apr 30, 2013 | 10:40 PM
Did you check the fuses? Usually when the OB2 scanner doesn't connect, it is a blown lighter fuse.
Old May 1, 2013 | 12:47 AM
canucklehead's Avatar
Ditto. Check all fuses and relays. My van loves to blow the fuse to the lighter and 12v power point on the engine cover for no reason.
Old May 17, 2013 | 2:22 PM
chris 419's Avatar
turned out my fuel pump just had intermittent problems it would work sometimes and not others. and I had a blown fuse for my obd2
Old May 18, 2013 | 10:29 PM
If your pump is seizing on and off, its on its way out, and will surely strand you somewhere.
Better change it soon. Once they get like this, they are a ticking time bomb.
Blaine B.
12
Apr 2, 2015 12:00 PM
LeeHamilton
Oct 26, 2014 9:49 PM
pathach5150
Jan 11, 2014 4:15 PM
hunter10220
May 18, 2011 8:37 PM
rowekmr
Jul 20, 2010 1:59 AM
