Chevy G30 Dash Buzzing Sound When Its Off
Old Apr 30, 2022 | 1:55 PM
HerzeleidMeister's Avatar
Default Chevy G30 Dash Buzzing Sound When Its Off
Hello. I went out and started my van today and when I opened the door there was a buzzing noise coming from the dash. The noise you hear when you turned off the van but forgot to turn off the lights.... Not sure how to describe it. When I start the van the noise stops and does not come back until I turn the van off again. So I thought that it might run the battery down if it were to go on for a really long time and I decided to check the fuses. I figured I could pull the fuse that was causing this issue so the battery would not die. I found the fuse and its the "STOP/HZ" fuse and its a 20. I took it out. What exactly does that fuse do? My guess is it has something to do with the hazard lights maybe? I was able to start the van just fine after taking it out. The fuse looked fine as well it was not blown nor did it have any corrosion on it or anything. How do I make the van stop buzzing with that fuse in? TIA!
Old May 4, 2022 | 3:33 AM
William Kisselstein's Avatar
That buzzer is a module you should be able to just unplug. They must be a known failure because several of mine have had it unplugged or removed. The one I drive now the seat belt light glows faintly most of the time and there's no buzzer ever, which makes me think it was disabled.
Old May 4, 2022 | 6:21 AM
Thanks, I have disabled it by taking the fuse out. I was just wondering if there was a way to fix this so if the fuse is in it does not make a sound.
Old May 5, 2022 | 7:36 AM
Yes. Put the fuse back, so you will have brake lights again, open the door, follow the noise to the module, and remove it. It should just plug in.
our chevy
Jul 10, 2024 1:17 PM
1987G20
Sep 9, 2013 11:07 PM
pecos
Astro
Jan 29, 2011 1:05 PM
Snotrocket
Oct 1, 2009 3:45 PM
drakemustaine
Aug 28, 2007 12:32 PM
