Climate Control Not Working
Old May 17th, 2022, 3:15 PM
  #11
sounds like you have some janky connections from vibration or something. Maybe grounding points have corroded, or rodents got into your wiring.
Old May 17th, 2022, 4:23 PM
  #12
funtwodrv's Avatar
We bought this thing new and for over a year it was all you could expect. Then one day, the instrument cluster started shutting down intermittently. The Chevy dealer found the chafed wire, fixed it and called it good. That lasted a bit over a year before doing it again. They reflashed the BCM and pulled the radio out claiming the radio was putting a load on the buss!
Bottom line, there is something amiss somewhere, just can’t find out where! Maybe another chafed wire, maybe a sketchy fuse panel, maybe a flaky ground who knows.
Old May 17th, 2022, 4:26 PM
  #13
funtwodrv's Avatar
Grounds!? Where are they? I removed and cleaned one on the chassis, engine and the one beside the battery. Anyone know where others may be hiding?
Old May 17th, 2022, 4:43 PM
  #14
Yeah I get the impression that the cutaway models are plagued with wiring problems.
There are many grounds. gmupfitter.com has routing diagrams that will show you all of them.
Old May 18th, 2022, 5:20 AM
  #15
funtwodrv's Avatar
I went through all 900+ pages yesterday and didn’t see the actual grounding locations…I’ll take another look at it today. If nothing else, I may run additional ground wires tying the body, frame and engine together.
Old May 18th, 2022, 3:01 PM
  #16
Originally Posted by funtwodrv
Express 4500 Cutaway Chassis climate control inop...
Year?
Old May 18th, 2022, 5:48 PM
  #17
funtwodrv's Avatar
2014 4500 chassis
I did pay better attention this time and identified the grounds and their locations. And as you mentioned, there are several and are located everywhere!
Jesse9657350
1988 - 1998 (GMT400)
January 14th, 2022 1:26 PM
bcrawfo2
August 22nd, 2016 9:20 AM
msmrx57
September 16th, 2010 8:21 PM
matt0912
July 9th, 2010 6:20 PM
dunk1
November 12th, 2009 8:26 PM
Quick Reply: Climate Control Not Working
