Climate Control Vacuum Tubing Issue
#11
a smoke tester is the most reliable way to find vacuum leaks
#12
Jumping on your thread
whats controls the air conditioning on the vacuum side of things? I had rats chew the vacuum lines so I replaced all the from a wrecker
but no air conditioning.fuses all good and relay.and ideas?
#13
AC is electric control. Did all the refrigerant leak out? Can you manually put power to the clutch and will it cycle then? There is a pressure switch too.
#14
haven’t put power to clutch yet and there was 10-5psi in the system. I added some to get is to 45 psi
#15
https://charm.li/Chevy%20Truck/2013/...Assembly%20X2/
Per the above green and white wire. Torque App will also tell you if the ECU sees the AC request.
#16
#18
It isn't all vacuum. There are a lot of wires here.
#20
