code p0054 bank 1 sensor 2 where is it?
Old Oct 5, 2014 | 3:25 PM
JT Kessler's Avatar
Default code p0054 bank 1 sensor 2 where is it?
2010 express 1500 popped the code p0054 which is the bank 1 sensor 2, is this the one on left side up high?
Old Oct 5, 2014 | 5:16 PM
bank one is on the driver side, sensor 2 is after the convertor...left side low...if its a heater code, make sure the fuse is ok.
Old Oct 6, 2014 | 9:54 AM
JT Kessler's Avatar
where would the fuze to that be located? in the fuze panel? or inline on the wiring of the o2 sensor
thanks
jeff
Old Oct 6, 2014 | 3:30 PM
canucklehead's Avatar
No fuse. 99% of the time this means replace the 02 sensor. Check the wiring to make sure it is not damaged also. Could be a bad connection.
Old Oct 6, 2014 | 11:04 PM
underhood fuse block o2 sensor2 (post) fuse 62. this fuse is for the 02 heater supply circuit.
most of the time the wiring rubs through on the frame and blows the fuse.
Old Oct 6, 2014 | 11:43 PM
JT Kessler's Avatar
Thank you so much i would have never thought of that, i replaced the sensor and cleared the code, ill check the fuse under the hood in the morning thank you
Old Oct 7, 2014 | 7:54 PM
JT Kessler's Avatar
Okay, i changed both of the o2 sensors on the passenger side, the fuses for the oxygen sensors were both good, where should i look now for the problem? the wiring? and how do i check the wiring
jeff
Old Oct 7, 2014 | 10:53 PM
you changed the wrong sensor. when referring to left and right for cars, left is from the perspective of sitting in the drivers seat.
you need to change b1s2 its the driver's side rear sensor.
Old Oct 8, 2014 | 3:18 PM
JT Kessler's Avatar
sorry i changed them on the drivers side, the fuses for the oxygen sensors were both good, where should i look now for the problem? the wiring? and how do i check the wiring
Old Oct 9, 2014 | 12:15 AM
If you change the bad sensors, have you cleared the codes and seen if its fixed?
