dies and stabilitrac blinks
Old Aug 12, 2020 | 5:57 PM
woodhooks's Avatar
Default dies and stabilitrac blinks
Help! Please! i have an intermittent problem where the "service stabilitrac" light dings once and the van dies .5 seconds after. No codes. i then put it in nuetral or park and turn the key forward, sometimes it starts right away, other times i have to turn the key off before starting it and it starts up again. it has happened while in park, and while at a stop light in drive. it happened driving 70, where the stabilitrac light blinks but that time the van did not die or sputter. the stabilitrac light never stays on. Is this a common issue at all?
i saw a video of a guy on youtube who found a 12v wire that was aftermarket for a fuel lift pump, and it was shorting out on the block; however, i have no aftermarket items except for trailer wiring.
I plan to crawl under and check every little wire, but I was hoping someone had experience. We are about to embark on an 1800 mile journey with a camper and I would like to get this figured out. I always travel with a full set of tools.
Old Aug 12, 2020 | 5:59 PM
woodhooks's Avatar
a final thought, it has happened when i am providing no input to the van, not touching or turning the wheel nor hitting the gas.
Old Aug 12, 2020 | 6:09 PM
this video ?
Old Aug 12, 2020 | 6:17 PM
woodhooks's Avatar
yep, thats the one, our issues seem to be the same except his was an add on wire that was ran unprotected and I have no aftermarket wires ran. i would think chevy would not have ran any wires unprotected and i would essentially be looking inside the wire harness sleeve, pita.
mikepell
Aug 26, 2013 4:56 PM
tuffgong1003
Jun 16, 2007 12:02 PM
stewdogg
Jun 1, 2007 10:32 PM
