Does '07 have compass/temperature mirror option
I was just wondering if the '07 Express had the option of installing a dimming mirror with built-in compass and temperature display. I was cleaning the inside windshield glass and noticed that there is a cut-out between the headliner and the windscreen where a wire from the dimming mirror would perfectly fit. And if so, does anyone know if there is a harness upd there already in place for install?
Not sure if your van is pre-wired or not. I have seen some pick-ups that were pre-wired, but didn't have the temp sensor under the hood.
Here's a link to an aftermarket mirror that will work for your van
http://www.pickupspecialties.com/compassmirror.htm
Thank you Shawn and EuroGold. So you, EuroGold, are saying that the harness is already in place by the headliner and all I have to do is plug in the dimming OEM mirror? If that is correct then great news! I hate going hunting for the it by the fuse box and then running the wirings to the headliner. Thanks
Got bad news for you, there is not a wiring loom behind the headliner. If you want a
dimming/compass mirror you will have to buy the kit, and run wires yourself. It is easy
to do, installed this mirror on a 06 and a 08.
You can buy the sensor and mirror at a junk yard but make sure you power up the vehicle to make sure it works before you pull it. You run the wire up the a-pillar and across to the mirror.
flbeachfront
April 7th, 2014 9:21 PM
earnestsierra
February 3rd, 2012 12:31 PM
For Sale: FS: 1967-69 dealer option dash compass
danialkenny
August 16th, 2010 10:03 PM
07, chev, compass, compasstemperature, express, gm, install, installing, mirror, sensor, temp, temperaturecompass, van
