Does '07 have compass/temperature mirror option
Old Feb 25, 2008 | 3:57 PM
07kastenwagen's Avatar
Default Does '07 have compass/temperature mirror option
I was just wondering if the '07 Express had the option of installing a dimming mirror with built-in compass and temperature display. I was cleaning the inside windshield glass and noticed that there is a cut-out between the headliner and the windscreen where a wire from the dimming mirror would perfectly fit. And if so, does anyone know if there is a harness upd there already in place for install?
Old Feb 27, 2008 | 8:46 PM
shawnvw's Avatar
Banned
Default RE: Does '07 have compass/temperature mirror option
Not sure if your van is pre-wired or not. I have seen some pick-ups that were pre-wired, but didn't have the temp sensor under the hood.
Here's a link to an aftermarket mirror that will work for your van
http://www.pickupspecialties.com/compassmirror.htm
Old Feb 27, 2008 | 9:01 PM
EvansBlue's Avatar
The wiring will be in place already. You'll have to put the thermometer in.
Old Feb 28, 2008 | 4:46 PM
Thank you Shawn and EuroGold. So you, EuroGold, are saying that the harness is already in place by the headliner and all I have to do is plug in the dimming OEM mirror? If that is correct then great news! I hate going hunting for the it by the fuse box and then running the wirings to the headliner. Thanks
Old May 6, 2008 | 2:37 AM
edward301's Avatar
Got bad news for you, there is not a wiring loom behind the headliner. If you want a
dimming/compass mirror you will have to buy the kit, and run wires yourself. It is easy
to do, installed this mirror on a 06 and a 08.
Old Aug 23, 2021 | 5:11 PM
Edward Andriaccio's Avatar
did you ever drop the headliner?if so what did you find?
Old Aug 24, 2021 | 9:47 PM
SteveROntario's Avatar
You can buy the sensor and mirror at a junk yard but make sure you power up the vehicle to make sure it works before you pull it. You run the wire up the a-pillar and across to the mirror.
Old Sep 12, 2021 | 12:41 PM
how did you do it?what kit did you use?
flbeachfront
Apr 7, 2014 9:21 PM
earnestsierra
Feb 3, 2012 12:31 PM
legolas894
Nov 28, 2011 9:53 PM
danialkenny
Aug 16, 2010 10:03 PM
technoteacher
HHR
Feb 24, 2006 3:43 PM
