Door panel glue separating
The rear door is separating from the rest of the door panel. Looks like the factory used some sort of foam adhesive that is now completely separated. Makes for a nice rattle.
Anyone repair this before?
stuff some more foam down there. Glue it in place.
jamesm113 (March 20th, 2022)
Something springy. Rubber foam such as neoprene. ( I think GM uses an expanding spray-on product but it's probably expensive)
Or polyethylene foam that electronics sometimes come packaged in.
Then you'll need a polymer safe adhesive. Window sealant would probably work.
Typically the material is foam backed and you can stick it down with rubber cement, the industrial kind you get in a hardware store. I did interior panels for my cargo van that way and they've held up fine.
jamesm113 (March 22nd, 2022)
colscott
March 31st, 2021 5:04 PM
