Door panel glue separating
Old Mar 19, 2022 | 8:56 PM
jamesm113's Avatar
Default Door panel glue separating
The rear door is separating from the rest of the door panel. Looks like the factory used some sort of foam adhesive that is now completely separated. Makes for a nice rattle.
Anyone repair this before?
Old Mar 20, 2022 | 10:31 AM
stuff some more foam down there. Glue it in place.
Old Mar 20, 2022 | 1:03 PM
jamesm113's Avatar
What type of glue/foam will hold up?
Old Mar 20, 2022 | 2:40 PM
that would work. there is also: bodyshop supply store or good part store and ask for panel adhesive. urethane for windshields works also but the adhesive is better.
Old Mar 20, 2022 | 4:14 PM
Something springy. Rubber foam such as neoprene. ( I think GM uses an expanding spray-on product but it's probably expensive)
Or polyethylene foam that electronics sometimes come packaged in.
Then you'll need a polymer safe adhesive. Window sealant would probably work.
Old Mar 22, 2022 | 4:09 AM
William Kisselstein's Avatar
Typically the material is foam backed and you can stick it down with rubber cement, the industrial kind you get in a hardware store. I did interior panels for my cargo van that way and they've held up fine.
Old Mar 28, 2022 | 8:03 PM
Trailrez1's Avatar
What I see in pic, is some aftermarket dynomat
colscott
Mar 31, 2021 5:04 PM
heshbamboo92
Jan 28, 2019 9:37 PM
thompjs
Dec 29, 2014 3:25 PM
David Pinkerton
Cobalt
May 29, 2013 4:31 PM
davemec
Sep 22, 2006 11:20 AM
