Driver's side "oh-$h!t-handle"?
Old December 11th, 2019, 4:10 PM
  #11
Twscarp's Avatar
Originally Posted by Triaged
The picture I posted might be computer generated but I have seen the handle in person on a cargo van at work. It is either a 2018 or 2019. There aren't many pictures of it online. I'll have to look into what RPO code gets you the handle. Driver at work said he uses the handle all the time to get in.
Hi, looks like digging into it more, the old style like mine (2008) was used through 2015, new style started 2016.
2015
2016
2017
2018
2019
Old December 11th, 2019, 11:35 PM
  #12
Triaged's Avatar
See pictures below. I'll have to check the year but it was bought in 2019.
Old December 11th, 2019, 11:49 PM
  #13
I have had bad problems on old GM tilt columns
What kind of problems?
Old December 12th, 2019, 12:40 AM
  #14
Triaged's Avatar
I had one where the ball bearings were overloaded and turned the ***** to powder and one where the bolts holding the column together loosen up putting a huge amount of slop in the steering wheel.
Old December 12th, 2019, 10:20 PM
  #15
StanVan's Avatar
My '16 has one, and it's broke. I'd stick with using the steering wheel.
Old December 17th, 2019, 12:36 AM
  #16
dberladyn's Avatar
For the Driver's Side Grab Handle, you need the anchor welded onto the A-Pillar. It's not going to be as simple as swamping the trim piece. I'd post a picture as my pillars are bare at the moment, but it's just not worth my time.
Old March 5th, 2023, 8:47 AM
  #17
Triaged's Avatar
Found it. www.ebay.com/itm/266046174624
GM 84937097
$70 here https://www.gmpartsdirect.com/oem-pa...-trim-84937097
Guess I'll have to buy one to get pictures of the inside and how it mounts.
Old March 5th, 2023, 7:27 PM
  #18
William Kisselstein's Avatar
Yes, the older tilt will loosen up if used as a handle. But the newer ones are an entirely different design.
jtexfisher
October 6th, 2014 11:45 PM
Rmbb
July 31st, 2012 11:28 AM
bschnacker
April 3rd, 2011 10:46 PM
ricco5
January 2nd, 2010 11:39 PM
justin2123
July 6th, 2007 7:37 PM
Quick Reply: Driver's side "oh-$h!t-handle"?
